Activity › Forums › Panasonic Cameras › Panasonic HMC150 focus problem
  • Panasonic HMC150 focus problem
    Posted by Chad Potts on July 27, 2010 at 9:32 pm
    I’ve had the camera for a few months but I’ve had this problem happen to me a few times and I want to know if I should be worried. When I perform a tight zoom to manually adjust my focus – the focus begins to jitter in and out rapidly while a noise can be heard in the camera. When I zoom out it is fine. This only happens occasionally but enough to make me worry – Everything is set to manual. Any ideas on what I should do would be great.
    Chad Potts
    Guy Mcloughlin replied 16 years, 2 months ago 2 Members · 3 Replies
  • Guy Mcloughlin
    July 28, 2010 at 2:26 am
    This sounds like you are using the auto-focus feature and NOT manually focusing the shot yourself.
    I NEVER use the auto-focus because it’s way too slow to keep up. Everything I shoot is manually focused.
  • Chad Potts
    July 28, 2010 at 3:53 am
    Hi Guy McLoughlin ,
    I wish it was that simple – I keep everything on Manual – and I have a second HMC150 that does has not had this problem. It first happened when I connected my Redrock adapter…Now it has happened at least 3 times since then without the adapter. I’m taking it on a full day shoot tomorrow and I’ll post what happens – anything else you think it could be?
  • Guy Mcloughlin
    July 28, 2010 at 10:36 am
    It sounds like it could be physical damage to the lens mechanism, which means you are going to have to take the camera to Panasonic and have them check it.
