Activity › Forums › Panasonic Cameras › Panasonic HMC-150 and FCP 2 requirements
  • Panasonic HMC-150 and FCP 2 requirements
    Posted by Marty Glembotzky on March 27, 2009 at 12:24 pm
    I am considering buying the Panasonic HMC-150 before the end of the month to take advantage of the rebate offer but am concerned if my setup will support it. Have been using the HVX-200 with DV tape as of late.
    I run with an OWC 250 firewire with the 9/11 chipset for my external drive. I just installed FCP 2. My hope is the below is enough info for the call to be made. Looks like a sweet camera.
    Any help would be much appreciated!
    Hardware:
    Hardware Overview:
    Model Name: MacBook Pro 15″
    Model Identifier: MacBookPro1,1
    Processor Name: Intel Core Duo
    Processor Speed: 2 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 2 MB
    Memory: 2 GB
    Bus Speed: 667 MHz
    Graphics/Displays:
    ATI Radeon X1600:
    Chipset Model: ATY,RadeonX1600
    Type: Display
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    Vendor: ATI (0x1002)
    Device ID: 0x71c5
    Revision ID: 0x0000
    EFI Driver Version: 01.00.068
    Displays:
    Color LCD:
    Resolution: 1280 x 800
    Depth: 32-bit Color
    Core Image: Hardware Accelerated
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    Built-In: Yes
    Display Connector:
    Status: No display connected
    Memory:
    BANK 0/DIMM0:
    Type: DDR2 SDRAM
    Speed: 667 MHz
    Status: OK
    BANK 1/DIMM1:
    Type: DDR2 SDRAM
    Speed: 667 MHz
    Status: OK
    Serial-ATA:
    Intel ICH7-M AHCI:
    Vendor: Intel
    Product: ICH7-M AHCI
    Speed: 1.5 Gigabit
    Description: AHCI Version 1.10 Supported
    Hitachi HTS722020K9SA00:
    Capacity: 186.31 GB
    Model: Hitachi HTS722020K9SA00
    Revision: DC4OC76A
    Serial Number: 071218DP0410DTG8BSJP
    Native Command Queuing: Yes
    Queue Depth: 32
    Removable Media: No
    Detachable Drive: No
    BSD Name: disk0
    Mac OS 9 Drivers: No
    Partition Map Type: GPT (GUID Partition Table)
    S.M.A.R.T. status: Verified
    Volumes:
    MacBook HD:
    Capacity: 185.99 GB
    Available: 90.89 GB
    Writable: Yes
    File System: Journaled HFS+
    BSD Name: disk0s2
    Mount Point: /
    USB:
    USB High-Speed Bus:
    Host Controller Location: Built In USB
    Host Controller Driver: AppleUSBEHCI
    PCI Device ID: 0x27cc
    PCI Revision ID: 0x0002
    PCI Vendor ID: 0x8086
    Bus Number: 0xfd
    Built-in iSight:
    Product ID: 0x8501
    Vendor ID: 0x05ac (Apple Inc.)
    Version: 1.84
    Speed: Up to 480 Mb/sec
    Manufacturer: Micron
    Location ID: 0xfd400000
    Current Available (mA): 500
    Current Required (mA): 100
    USB Bus:
    Host Controller Driver: AppleUSBUHCI
    PCI Device ID: 0x27c8
    Bus Number: 0x1d
    Applications:
    Final Cut Pro:
    Version: 6.0.5
    Noah Kadner replied 17 years, 6 months ago 2 Members · 3 Replies
