Activity › Forums › Panasonic Cameras › Panasonic HD LCD questions
  • Panasonic HD LCD questions
    Posted by Charles Lorch on August 10, 2005 at 2:47 pm
    I was looking at the Panasonic 17″ HD LCD (BT-LH1700W) on the Panasonic site and had a couple of questions about some of the features listed.
    It talks about a waveform feature. Is this simply an overlay image that can be input from a separate waveform, or is the monitor itself a waveform? If so how acurate/reliable is it? Would you still need an HD waveform in the suite or field?
    It also lists CineGamma Compensation, specifically for the Varicam. I understand CineGamma since we own an SDX-900, but what exactly is this feature and it’s benefit?
    Thanks.
    Charles Lorch replied 21 years, 1 month ago 2 Members · 2 Replies
  • Chris Bell
    August 10, 2005 at 3:15 pm
    The waveform is good for field production to make sure you are in the range. Anyone experienced with a waveform should have no problems. The cinegamma correction on the monitor is ONLY for when you are shooting for a film out and the camera is set at 500% dynamic range, and 45 on the master gamma. If you are shooting for broadcast, keep it in the standard gamma setting.
    I orderd my 1700w yesterday… I look forward to seeing it soon. Great price for a 17″ broadcast monitor!
    Chris Bell
  • Charles Lorch
    August 10, 2005 at 4:30 pm
    Thanks for the info.
    So there is a functioning waveform built into the monitor?
    Please post back when you get the monitor in, and let me know what you think.
