Activity Forums Apple Final Cut Pro Legacy Panasonic Frame Rate Converter again
  • Panasonic Frame Rate Converter again
    Posted by Sergio Deustua on November 23, 2006 at 4:02 pm
    Hi everyone.
    Twor questions:
    1.- Just get the Panasonic Frame Rate Converter Plug-in for FCP and it seems is not working. I tried first with a 720p 24 clip shooted in the HVX200, and it show the message than only 59.94 footage in supported. So I tried with another clip shooted in Varicam and captured wiht the Easy set up DVCPROHD 720p 60 settings via firewire. This clip is, surely, in 59,94 but the message of the converter is the same: only 59,94 footage is suported. So, don
    Sergio Deustua replied 19 years, 10 months ago 3 Members · 3 Replies
  • Mactrix
    November 23, 2006 at 5:20 pm
    No, the FRC can convert 59.94 to 23.98 not the other way around.
    To convert 23.98 to 59.94 you can use After Effects, Shake or
    even Compressor …
  • Gary Adcock
    November 23, 2006 at 5:47 pm
    [langosta] ” Just get the Panasonic Frame Rate Converter Plug-in for FCP and it seems is not working.”
    In fcp 5.1.2 you HAVE to use the version that comes in the extras folder on the UB installer disk, the version from the web will not work.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Sergio Deustua
    November 24, 2006 at 9:34 am
    Thank you.
    Ir works now.
