Activity › Forums › Apple Final Cut Pro Legacy › Panasonic DVC Pro25 deck via FireWire to Non-controlable device
  • Panasonic DVC Pro25 deck via FireWire to Non-controlable device
    Posted by Chris Poisson on September 25, 2008 at 9:46 pm
    I have this old deck at a place I work, it’s set to DV, hooked up via S video to a DVD/VHS player/recorder, which is what I want to capture from using the VHS side. I’m seeing an audio signal on the meters of the DVC Pro deck, but nothing out to the FCP capture window.
    I used to capture VHS like this at home through my DSR 11, but no go with this setup. Any thoughts?
    Have a wonderful day.
    Rennie Klymyk replied 18 years ago 3 Members · 3 Replies
  • Matt Larson
    September 26, 2008 at 9:18 pm
    Is there a switch to choose which input Composite/S-Video, etc.
    Do you have a TBC there? Try running the VHS through a TBC to stabalize the video. In order to get the cable TV signal at my ofice on a plasma (hooked up with SDI), I have to send it through a VCR with TBC so the DA Converter can work with the crappy signal.
  • Chris Poisson
    September 26, 2008 at 11:18 pm
    Hey Matt,
    Yeah, I had that same thought, I have a TBC at home I can bring in, so thanks.
  • Rennie Klymyk
    September 27, 2008 at 7:06 pm
    Also a lot of the dvcpro decks are menu deep- meaning there may be a menu setting for passthrough.
    “thou can not stir a flower without crumbling a star” ……Henry Wadsworth Longfellow
