Activity › Forums › DaVinci Resolve › Panasonic BT300
Juan Salvo
May 3, 2012 at 3:30 amWe have a model like this, but with wheels.
https://www.premiermountsstore.com/premiermounts6072or84inchhighdualdisplayfloorstand-psd-cs.aspx
online editor | colorist | VFX | BD author
Paul Provost
May 3, 2012 at 3:31 amthat’ll work!
https://www.postandbeam.tv
grade and finish @ post + beam
https://www.facebook.com/pages/post-beam/137967176232067 -
Stig Olsen
May 3, 2012 at 10:02 amNice to know, we actually ordered one that will be delivered on monday!
Dylan: Check out our latest commercial, in which your company did all the post! – https://vimeo.com/40215674
Pass: sheriff123Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Teo Rižnar
May 4, 2012 at 12:10 pmI am using 50″ model for 3 months now. I do not have a LUT box, I have just come with the internal CMS and lots of different settings very close do the R709. I am profiling it with LightSpace CMS and it gets quite nice results. On SONY BVM 20″ CRT the image looks (and measures with probe) very very close to Plasma. By eye nobody can se de difference (clients).
Out of the box is quite far from the spec, but you can get close without a LUT box (just need the probe an CMS to measure what are you ding). Now I am judging between Davio and HDlink, I like Davio because of two LUTs, I can use one for CRT and one for panny, but still you get two HDlinks for price of one Davio.So far I am just finishing a feature film and the proces from Resolve suite, panny+CRT to DCP screenings the results are very good. CRT is the same as DCP but panny just crushes the blacs for a little, like 1-3 IRE on bottom of waveform just get a bit smashed. But I believe the LUT box can fix that.
How do you feed your pannys with unscaled or normally scaled legal video, for video out processing? There are some ranges of the chroma that panny just clips off… but never in the grading session, just on test charts.
Color grade reel: https://vimeo.com/15480583
Cofounder of https://nuframe.si postproductionSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Gabriele Turchi
May 4, 2012 at 5:23 pmIsn’t it the Davio 6000 usd and the HDLink 500 usd ?
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX470
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Ultrascope -
Paul Provost
May 4, 2012 at 9:15 pmDavio = 2 luts & 2 sdi out
Bmd = 1 lut & 1 hdmi outDavio also has higher precision luts
Gabriele Turchi
May 4, 2012 at 11:30 pmWhat is the price I Davio ?
gDavinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Ultrascope -
Paul Provost
May 4, 2012 at 11:41 pm$5K for davio
plus you need a profile / calibration software suite ($5k) & probe ($5k) .
about $15k total to do it right. this allows for independent luts for grade 1 broadcast monitor and client plasma.
probably better to hire out calibration tech regularly?https://www.postandbeam.tv
Neil Sadwelkar
May 8, 2012 at 2:49 pmBMD HDLink Pro = 1 LUT, 1 HD-SDI out, plus 1 DVI/MiniDP/HDMI out.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Paul Provost
May 8, 2012 at 3:27 pmSdi is only loop through?
