Activity Forums Apple Final Cut Pro Legacy Panasonic BT-LH1700W vs. ACD+HD Link
  • Panasonic BT-LH1700W vs. ACD+HD Link
    Posted by Scott Davis on November 17, 2008 at 6:54 pm
    Any thoughts on using a Panasonic BT-LH1700W vs. a Cinema Display via an HD Link to finish on?
    Project is low budget straight ahead doc. Footage is very good to begin with and final grade will not be complex. Final delivery is PBS.
    Thanks for any comments.
    Scott Davis
    View Scott Davis's profile on LinkedIn
    John Fishback replied 17 years, 9 months ago 3 Members · 4 Replies
  • Shane Ross
    November 17, 2008 at 7:04 pm
    PBS? They are friggin strict!
    PANASONIC…all the way. You can properly calibrate the monitor to color bars…VERY IMPORTANT. Not sure if you can with the HD LInk…can you? I know you can calibrate the ACD with the MXO. But I have no experience with the HD Link.
    But…if it can calibrate the ACD to bars…I might feel comfortable with it. I am comfortable with the MXO/ACD solution. But I get stern talks from professional colorists for than stance.
    Shane
  • Scott Davis
    November 17, 2008 at 9:16 pm
    Thanks Shane, I was hesitant about the ACD and HDLink for that very reason.
    On a side note. What do you mean by friggin strict? I looked at their TOS and it looks fairly normal.
    Scott Davis
  • Shane Ross
    November 17, 2008 at 9:20 pm
    [Scott Davis] “do you mean by friggin strict? I looked at their TOS and it looks fairly normal. “
    Then you might be used to tough broadcast standards like I am. When beginners ask about broadcast TV specs, we always point to the PBS specs, because they are the toughest around. Discovery’s were tough, but only because of the timing of commercial breaks.
    Shane
  • John Fishback
    November 18, 2008 at 10:53 pm
    We have the Panny 1700 and also a MXO + ACD. Before we got our new monitor, we edited with the MXO + ACD. I put the Panny beside it as a test and they were very close.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
