Activity Forums Apple Final Cut Pro Legacy Panasonic AJ1200A Shuttle Woes
  • Panasonic AJ1200A Shuttle Woes
    Posted by Michael Harnois on May 24, 2005 at 6:49 pm
    While loading DVCPRO HD into FCP via a rented Panasonic AJ1200A, I could not get the machine to shuttle any faster than 4x. The rental house claims that as long as you use either the firewire or serial port options to control the device, this is normal. I say “Can’t be”. Can it?
    Anyone shuttling within FCP any faster?
    Michael Harnois
    Stealth Fighter Pilot/Senior Editor
    The Troupe – Windham, NH
    Michael Harnois replied 21 years, 3 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    May 24, 2005 at 8:41 pm
    Dig through the menus and play with the max shuttle speed.
  • Michael Harnois
    May 25, 2005 at 3:06 pm
    Been there, done that.
    Set it to 50X, but she still no go.
    Michael Harnois
  • Jeremy Garchow
    May 25, 2005 at 6:49 pm
    You can most definitely go faster.
    I have to ask, but you are hitting j (rewind) or l (ff) multiple times, correct? With the mouse (not the keyboard) hit stop and then hit rewind of ff.
    Jeremy
  • Michael Harnois
    May 27, 2005 at 7:24 pm
    Yes, I have mastered the JKL long ago. Do you have experience with shuttling this deck or are you assuming that it SHOULD go faster? I would assume that as well, but it is proving different. We will have the deck in again next week so I’ll experiment some more.
    Thanks for your insight,
    Michael Harnois
