Activity Forums Apple Final Cut Pro Legacy Panasonic AJ-D250
  • Panasonic AJ-D250
    Posted by Dean Goldsworthy on September 14, 2005 at 4:49 pm
    I have FCP 4.5 and have been importing footage with no problems using firewire as long as I use the DV/DVCPro codec.
    Is there a way to get 601 720×486 uncompressed 8/10 bit out of the D250 via firewire?
    I’ve tried creating my own capture settings without luck. For one thing under device control and fire wire it only shows 720 x 480 and you can’t create a new configuration. Also under capture presets the “digitizer” option only shows “none” or “DV video”.
    Thanks for your suggestions, Dean
    Dean Goldsworthy replied 21 years ago 3 Members · 4 Replies
  • Joe Paolo
    September 14, 2005 at 7:20 pm
    Firewire will do DV 720×480 411 or DV50 720×480 422. You’ll need to go out to SDI to get true 601 720×486 422. Can you explain why you need to do this?
    joe
  • Dean Goldsworthy
    September 14, 2005 at 7:43 pm
    Sure, we have diffent edit systems. Some do dv, some do uncompressed.
  • Jan Crittenden livingston
    September 15, 2005 at 10:04 am
    The AJ-D250 does not have a 601 output nor will the firewire allow a 720 by 486 output.
    Hope that helps,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Dean Goldsworthy
    September 15, 2005 at 12:39 pm
    Jan,
    Thanks for chiming in with THE definitive answer.
    -Dean
