Activity › Forums › Apple Final Cut Pro Legacy › Panasonic AG-HMC70U + FCP 6.06 = happy marriage?
Posted by Alan Langdon on June 7, 2010 at 10:56 pmHello. I would like to know if FCP 6.06 can edit, probably via Log & Transfer footage shot on the Panasonic AG-HMC70U camera (AVCHD, I believe, is the codec). Is the workflow basically the usual Log & Transfer where you convert the fotage to Apple Pro Res or Intermediate Codec?
Jerry Hofmann replied 16 years, 3 months ago 2 Members · 3 Replies -
Jerry Hofmann
June 13, 2010 at 6:52 pmFCP 6 supports AVCHD by importing it as ProRes. Good thing IMHO. Larger files, better editorially and better with all graphics etc…
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Alan Langdon
June 18, 2010 at 6:57 pmApparently, this camera records anamorphically, at 1440×1080, which then stretches back to 1920×1080 inside de system, right?
What is the best workflow to get this footage edited and then put onto miniDV, since the client I am dealing with only accepts material as regular SD DV.I edited a sequence in full resolution (Apple Intermediate Codec) and then put the HD export onto a DVD via Toast and it looks like the resolution suffered, it looks worse than regular DV footage… Is this because the HD footage is Upper Field?
What would be the best workflow from footage shot on this camera to SD minDV / DVD?
Jerry Hofmann
June 21, 2010 at 4:44 amSorry didn’t see you’re post before now.
You can simply edit in the ProRes 1080, then send the finished sequence to compressor and transcode it there if you don’t have a capture care which would do this in real time just playing the sequence and down converting it. The AIC codec you edited with stomped pretty badly on the HD and it may well be the reason your SD looks substandard. It’s a garbage in/garbage out situation. ProRes won’t hurt your video as much to begin with so the end SD product should look very good.
Jerry
