Activity Forums Panasonic Cameras Panasonic AG-HMC150 how to get footage into Imovie
  • Panasonic AG-HMC150 how to get footage into Imovie
    Posted by Christina Rule on January 12, 2011 at 5:33 pm
    Hello,
    A friend of mine just purchased Panasonic AG-HMC150 he uses high speed scan disc cards for capturing his footage. How would he go about importing the files into Imoive?
    I’ve only worked with P2 cards and FCP so I figured I’d post here and see if anyone had any suggestions.
    Thanks in advance!
    http://www.christinarule.com
    Christina Rule replied 15 years, 7 months ago 2 Members · 4 Replies
  • Daniel Schultz
    January 13, 2011 at 2:40 am
    I imported/transcoded files into imovie once when I first got my camera, and before I had Final Cut. It seemed pretty easy, from what I remember. Plug the disk into the computer and launch imovie. But it has been a while.
    Dan S.
  • Christina Rule
    January 13, 2011 at 5:01 pm
    Thanks. Yea that’s why I thought. He seemed to be having some issues with it, it makes it more difficult to give advice when I do not actually having the camera in-front of me. I just wanted to make sure if it was possible to directly import from the camera into imovie wasn’t sure if you had to convert the files or anything like that.
  • Daniel Schultz
    January 15, 2011 at 12:46 am
    I believe imovie does transcode the files. But it probably has to be a fairly recent version of imovie to recognize the avchd. Good luck.
    Dan S.
  • Christina Rule
    January 25, 2011 at 6:06 pm
    Do you know if he were to moved the files from the SD card to a hard drive will Imovie still recognize them?
