Activity › Forums › Apple Final Cut Pro Legacy › Panasonic AG-HMC150 720p30 Footage in FCP
Jonas Bendsen replied 14 years, 7 months ago 11 Members · 14 Replies
Jeremy Lyverse
February 6, 2010 at 5:11 pmHi Felix, it looks like we have the same gear/workflow set up, and after reading many posts on here feel lucky to get in the game at this level. Production and editing has been smooth for me as well. I was wondering about your experiences with outputting/compressions/etc. Mine seem to be a bit pixelated and choppy for such a high level workflow. How are you saving/outputting your work, and for what medium, web, broadcast? I’ve been outputting through apple compressor thus far. What sequence settings in fcp 7 did you find to work the best for you? Just curious of your experiences and results. Thanks.
Courtney Walsh
April 9, 2010 at 4:47 pmI have a brand new 150 and Final Cut pro and also noticed rough edges when using Apple Compressor.
Things better when exporting to Quick Time Conversion, mp4 with H264 and 1280×720, data rate 2048, frame 29.97.
Any other ideas on compressing welcome.
Also on the best setting for shooting in low light.
Thank you, Courtney
Clint Collins
February 25, 2011 at 8:46 pmGuys, I am trying to import my footage. I just recently purchased the AGHMC150. I did some test footage and then went to import it into FCE. I popped the SD card into my MacBook Pro, but nothing. It won’t read/recognize or import the footage from the card. I opened log and capture in FCE and nothing is even showing up, even though all the footage is playing fine on my camera. Any ideas???
Jonas Bendsen
February 20, 2012 at 11:24 pmI came across this thread doing research on this camera, because we’ll be shooting a project with it this weekend. This is also the first time I’ll be shooting something that’s NOT 23.976.
I notice in the manual it states:
“For output and recording, the 30-frame-per-seoncd signal is converted to 60-field-per-second interlace. This mode gives you high quality images.”
The signal specs also state:
“1080/60i, 1080/30p (over 60i), 1080/24p (native), 720/60p, 720/30p (over 60p), 720/24p (native)”
First of all, why would they do this (30p is actually 60i)? I don’t want interlaced footage; I want progressive. Second of all, I assume this is perhaps the reason the original poster is seeing 59.94 instead of 29.97.
If the footage is interlaced, I can’t easily toss out the second field of this 60i footage (without de-interlacing and losing resolution), so it seems I’m stuck with interlaced looking footage (60i) whether I like it or not. Is this true?
Thanks to anyone with answers.
This is my life, I edit and edit and edit and edit…
