Activity › Forums › Panasonic Cameras › Panasonic AF101 with lens adapters
  • Panasonic AF101 with lens adapters
    Posted by Tone Andersen on July 9, 2013 at 11:12 am
    I have recently bought the Panasonic AF101 and was very excited to try my old stills photo lenses with it. I bought the kipon “FD to mft” and the “EOS to mft” and tried the adapters with an old canon 50mm FD mount lens and a Canon 28-135 EF mount lens.
    I have no problems fitting the adapters and the lenses, but when I switch on the camera, there is only black.
    I have tried different settings and adjusted the iris back and forth. Is there a specific setting the camera must be on or why is this not working?
    Best,
    Tone
    Tone Andersen replied 13 years, 2 months ago 2 Members · 3 Replies
  • Pino Brambilla
    July 11, 2013 at 8:51 am
    You must disable the lens check. Look at the Menu: OTHER FUNCTIONS-LENS CHECK- set to OFF.
  • Pino Brambilla
    July 11, 2013 at 9:08 am
    You have to deactivate the Lens Check in the Menu. Look at the Menu: OTHER FUNCTIONS-LENS CHECK set il to OFF. Hope it can help.
  • Tone Andersen
    July 11, 2013 at 3:05 pm
    Great, it worked, – I now have lens options !
    Thank you
