Activity Forums Apple Final Cut Pro Legacy Panasonic 1400a Deck Firewire question
  • Panasonic 1400a Deck Firewire question
    Posted by Suncloud on May 21, 2007 at 6:03 pm
    I’m renting my Panasonic 1400HD deck out (I use HDSDI and the renter is using the firewire port – into Avid Express) . . . and he can’t get a downconverted SD (DV) signal out through the firewire . . . is HD the only format passable through that firewire port? (He CAN get the 720p signal when he is importing into an Avid HD project, but CAN’T get a DV Stand Def. signal going into a “DV project.” Any ideas?
    Suncloud replied 19 years, 4 months ago 3 Members · 3 Replies
  • Walter Biscardi
    May 21, 2007 at 6:08 pm
    You have to go into the 800 menus to change this. Can’t remember exactly which one, but it’s somewhere in the 800 section of the menus.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Gary Adcock
    May 22, 2007 at 12:41 pm
    [suncloud] “‘m renting my Panasonic 1400HD deck out (I use HDSDI and the renter is using the firewire port – into Avid Express) . . . and he can’t get a downconverted SD (DV) signal out through the firewire “
    As walter said
    you need to set the deck to down convert via the FW port.
    It is the 880 menu that allows for the conversion to DV from the HD masters
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Suncloud
    May 22, 2007 at 4:08 pm
    thank you!
