Activity Forums Apple Final Cut Pro Legacy Pana DVX100a Issues with FCP
  • Pana DVX100a Issues with FCP
    Posted by Tim Vaughan on July 16, 2005 at 3:09 pm
    Hi
    Whenever I use the multi-cam feature within FCP, I have a timecode issue with the Panasonic. The tapes are imported using their perspective camera’s, and I have not had any issues with the Sony VX series or the Canon Series of mini-DV cameras. However, when aligning my in and out points and syncing all camera’s up on the timeline, when I click the in point of the timeline, the timecode does not match up with the timecode of the master tape. (For instance, frame 1:00:00 on the timeline would be frame 00:56:14 on the master tape) Any clue? I have figured out this happens, so I am prepared for it: it is still a bother nonetheless)
    Tim
    Dual G4 867, 2GB RAM, FCP 5.02, 900GB internal space
    Dan Riley replied 21 years, 2 months ago 3 Members · 3 Replies
  • David Battistella
    July 17, 2005 at 3:29 am
    Perhaps this a 24P puldown related thing?
    The other cameras do not shoot a true progressive image at 24frames so manybe that is where the time discrepency lies.
    David
  • Tim Vaughan
    July 17, 2005 at 4:30 am
    We are shooting in NTSC 29.97. But possibly it could have an effect. Interesting probablility.
  • Dan Riley
    July 18, 2005 at 2:26 am
    I can’t get my DVX100 to work with FCP via firewire.
    When I go to log and capture, FCP says the camera
    is in “local” and won’t control it or give me timecode.
    I get picture but have no control.
    I checked the camera menu and it says VTR1 or VTR2.
    I’ve tried both and neither works.
    I can go to “non controllable” and use capture now
    but then I don’t get timecode info.
    Do you know how to make it work?
    Dan
    Oh, and for your problem…do you think it’s a drop frame,
    non drop frame problem? Have you checked to see
    if both source tapes are the same? Just a thought.
