Activity › Forums › Apple Final Cut Pro Legacy › Pana 50″pro plasma
Pana 50″pro plasma
Posted by Margus Voll on October 8, 2008 at 9:10 amHi
I wonder if enyone can tell me if i should get SDI or HDMI input board on subject. It has been discussed here this is why i ask this forum.
Margus
Chris Borjis replied 17 years, 11 months ago 5 Members · 6 Replies -
Mark Raudonis
October 8, 2008 at 10:28 amWe have several of these monitors. They’re great. Yes, we have the HDSDI boards for them, but they are NOT cheap! Having these boards makes for the easiest interface between source and monitor. At a professional level, your only other option would be to get a HDSDI >>> to HDMI converter box from AJA or Blackmagic. Those boxes are around $500 bucks. The Board for the Panasonic is around $1500.
If audio sync to source is important (protools, or editing) then you may want to stay with the built in board. If latency is not as crucial, you can probably get away with the converter.
Mark
Margus Voll
October 8, 2008 at 10:32 amMy BM Multibridge Pro has hdmi out and sdi out.
This is why i wondel which way to go.hdmi board is about 300 bucks and sdi is 1800 or someting like that.
Sync is no problem with multibridge i think.
Margus
Walter Biscardi
October 8, 2008 at 11:43 amHDMI is now standard on this unit (or maybe it’s the 42″). If you need HDMI, then get it.
Don’t waste your money on SDI unless you really feel like you need it. We have the 50″ and 2 of the 42″ models in our shop and they all have dual Component inputs.
The two that are connected to our BluRay players also have HDMI as we use that for viewing.
I’m pretty sure Panny added HDMI standard to all their screens last year but you’ll need to double check on that. I know the 42’s come with a dual HDMI input standard now.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Margus Voll
October 8, 2008 at 11:50 am -
Jason Porthouse
October 8, 2008 at 5:59 pmI’m running Component out of the Multibridge to my 42″ at the moment, and it looks spankingly good on HD, and surprisingly good on SD. Yet to try HDMI but will do at some point.
JP
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Chris Borjis
October 8, 2008 at 6:26 pm[Jason Porthouse] “I’m running Component out of the Multibridge to my 42″ at the moment, and it looks spankingly good on HD, and surprisingly good on SD. Yet to try HDMI but will do at some point.”
I have the same setup (multibridge extreme model on a 50″ plasma) with HDMI there is
an out of field order issue you may experience. I gave the requested data output
to black magic nearly 2 years ago and they have to this day not addressed the issue.its no surprise that SD looks good on a plasma, the pixel structure mimics CRT
far more than LCD does, especially the Panasonic line.
