Activity Forums Avid Media Composer Pan Zooms on graphics with alpha channel
  • Pan Zooms on graphics with alpha channel
    Posted by Mutzie on August 21, 2005 at 1:01 am
    Hi there,
    I am new to Avid and I can’t get my head arround how to apply a Pan Zoom Effect to a png file that I created in Photoshop. What I was hoping to achieve is this:
    Create a slightly larger txt graphic with alpha in Photoshop 3072×2304 72dpi, then add a filler clip to the V2 in my timeline in Avid Xpress Pro. In V1 is my video footage that I want to use as my BG for the txt.
    Now I apply the Pan Zoom effect onto the filler clip (drag and drop) and then open the effects editor to link it to my larger source file the png.
    When I then select the BG to be video, avid doesn’t seem to recognize the alpha channel. What I am getting is a squished white box over my video footage…..What am I doing wrong?
    Cheers
    Murlee replied 21 years, 1 month ago 2 Members · 1 Reply
  • Murlee
    August 23, 2005 at 12:23 pm
    Hi. Avid understands the use of Alpha in the opposite of how other applications use it. Go to import settings and choose “invert existing”. HTH
