Activity Forums Adobe After Effects Pan is shocking
  • Pan is shocking
    Posted by Fabienne De vries on September 24, 2021 at 5:22 pm
    Hi! I have a very wide composition filled with Illustrator characters and the camera is passing them by. When I’ve rendered the composition the characters are a bit unsharp (but in the composition they are sharp) and it’s also a bit shocking, like you sometimes have with “field on” with video footage. I tried it with: pulling a camera from left to right, just pulling the position from left to right and with the effect “transform” pulling position left to right but still the same result. Help!
    Fabienne De vries replied 4 years, 11 months ago 3 Members · 3 Replies
  • Eric Santiago
    September 24, 2021 at 5:52 pm
    Please post example.
    Also, if your camera frame changes to abrupt there isnt much you can do.
    Its the same issue with actual digital film cameras.
  • Michael Szalapski
    September 24, 2021 at 7:27 pm
    It sounds like you’re describing “judder”. So search for how to solve that and see if it helps.
  • Fabienne De vries
    September 28, 2021 at 8:31 pm
    Thank you so much for your responses, googled Judder and “Motion Blur” did the trick!
