Activity Forums VEGAS Pro Pan crop tool selecting edge to start or finish
  • Pan crop tool selecting edge to start or finish
    Posted by Paul Gregory on July 9, 2010 at 5:30 am
    I have lots of stills that I wish to use the pan zoom tool on. If I wanted to start or finish a zoom at the edge of a still of the still is there any easy way to nominate the edge without manually moving both the vertical & horizontal tool.
    Thanks in advance
    Paul Gregory replied 16 years, 1 month ago 3 Members · 3 Replies
  • John Rofrano
    July 9, 2010 at 2:35 pm
    Nope. The Pan/Crop tool has no such function.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Aleksey Tarasov
    July 9, 2010 at 2:43 pm
    It is not clear what you want. Can you describe in more detail?
  • Paul Gregory
    July 10, 2010 at 1:09 am
    One example would be if you double clip on a clip to select it & you wished to just zoom in from that view that occupies the entire screen down to something that rests against the bottom edge. To do this I just move the selection handle to make my selection zoom in. This zoom maintains the pictures original ratio. The new selection is now smaller but its located in the center of the original.
    Because I want the bottom of my selection to touch the bottom edge of the frame I still have to drag the entire smaller selection down so that it touches the bottom. Once its touching the bottom edge I still might have to re size the selection to get the cropping correct. If the selection tool had allowed my new selection to snap to to any selected edge this whole process would have been easier. I hope that you can understand just what I’m about.
    Thanks in advance
