Activity Forums VEGAS Pro Pan crop tool jitters?
  • Pan crop tool jitters?
    Posted by Grant on August 29, 2006 at 6:39 am
    Hi, I have just finished a 45 min documentary. I have been working in draft mode in Vegas 6d for the last 5 months & have loved it. I made the DVD to present to the client today & had to call them up & say it was not ready because there are some clips that shake/jitter & have some shadowed lines around people talking. When I apply reduce interlace flicker under the Edit/Switches it does not jitter any more but the quality of the image is significantly reduced. Definitely not good enough for broadcast.
    The problem is I don’t know how to fix it. I have cropped most images with a letterbox type psd mask & repositioned the clips with the pan/crop tool. They all have colour correction. That
    Grant replied 19 years, 12 months ago 2 Members · 3 Replies
  • Mike Kujbida
    August 29, 2006 at 6:23 pm
    Grant, I vaguely recall reading in a Vegas forum somewhere about the pan/crop tool sometimes changing the field order from lower to upper. As I recall, a possible solution was to adjust the pan/crop settings to be one line higher or lower. Another suggestion was to try a very small amount (0.001) of (horizontal??) gaussian blur. Hopefully someone else has other suggestions for you.
  • Mike Kujbida
    August 29, 2006 at 6:26 pm
    Correction. Change horizontal gaussian blur to vertical.
  • Grant
    August 30, 2006 at 2:36 am
    Thanks for your response, changing to upper field did not seem to work. The Gaussian blur did work but blurred the image a little too much by the time it removed the flicker. I am sure on some images it would be ok. The vertical Gaussian blur was better than the horizontal. Thanks for pointing that out.
    The best solution I have found is to apply the “REDUCE INTERLACE FLICKER” to the clip, then apply a sharpen filter to take out the blurring it creates. It seems to work well. Unless there is any other simple solution out there ? I will go down that path.
    Grant.
