Activity Forums VEGAS Pro pan-crop timeline zoom level
  • pan-crop timeline zoom level
    Posted by John D’orazio on April 20, 2012 at 9:58 am
    I’m using Sony Vegas Pro 11 build 595 64bit with Windows 7 Pro 64bit, and there is something very annoying that happens:
    every time there is a popup notification in Windows 7, the zoom level on the timeline in the pan / crop / masking window goes back to 0. I’ll be doing some fine masking work frame by frame and I’ll have the timeline zoomed in so that I can add keyframes at almost every frame or every other frame, when poof a popup notification from Windows 7 comes up and my zoom level goes back to 0. Nothing happens to my work, I just have to zoom in again on the keyframe I’m working on. This can get annoying.
    Any way of letting the Sony Vegas people know? This could be a very useful enhancement: not lose the zoom level on the timeline when Windows popup notifications come up!
    John D’orazio replied 14 years, 4 months ago 2 Members · 2 Replies
  • Frederic Baumann
    April 21, 2012 at 12:08 pm
    This looks weird! What do you exactly mean by notification? Things like windows updates being available?
    I would like to try to reproduce this pb. Can you suggest a way to have such notifications, happen on my pc?
    Will let you know if I get the issue as well (never had such, but not sure I have ever panned/zoomed when a windows update popped)
    Frederic
    FBmn Software: Professional GPU-powered plug-ins to fix White Balance and Exposure issues in a few clics.
    Color-matching made easy with the ColorMatch plug-in.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
  • John D’orazio
    April 21, 2012 at 1:25 pm
    I now see that it happens every time the pan / crop / masking window loses focus. If I zoom in on the timeline, then click somewhere outside of the window, the zoom goes back to default = 0. The cursor stays in the same place on the timeline, I have to zoom back in again to the keyframe I am working on. This is especially annoying when I have many keyframes close together, so I have to zoom in to select a precise keyframe. This only happens if the program window itself loses focus (i.e. if I click away to my browser or to another program window). When I bring focus back to Sony Vegas the zoom level on the timeline is back to default. When I spoke of Windows 7 popup notifications, I guess they effected this issue also because they must make the current program window lose focus.
    I also notice that while CTRL-RightArrow should advance the cursor to the next keyframe on the timeline, even though it does select the next keyframe it actually advances the cursor to right after the keyframe. Which means that if I make a modification in the masking, it will create a new keyframe in the actual cursor position instead of modifying the one I that is selected. This is a little annoying also, CTRL-RightArrow isn’t much of a shortcut for advancing to the next keyframe if the cursor winds up advancing further than the next keyframe.
    Here are a couple of screenshots which further illustrate the issues:
    1. Timeline zoomed in
    2. Timeline after Sony Vegas loses focus, now zoomed back out to zero:
    3. Cursor position after advancing to next keyframe with CTRL-RightArrow shortcut:
    As you can see, the next keyframe is selected but the cursor is positioned after the keyframe. So any modification to the masking will not be applied to that keyframe; instead a new keyframe will be created in the current cursor position!
