Activity Forums VEGAS Pro pan & crop issue
  • pan & crop issue
    Posted by Martin Phillips on August 27, 2009 at 7:27 am
    Hi there,
    pretty new to vegas, and have pro 9…. i have a shot of a moderate pan across left to right… the shot looks fine, but i have to zoom in slightly (you can just see the wind sock in the top left of the frame !!). So i have gone into ‘pan & crop’ and zoomed in just a little. On then reviewing the shot on the timeline, as the camera pans the image goes all jiggley (like its an interlacing problem)Go back into pan & crop and undo the zoom, and no problem…. i guess there is a setting somewhere i not using… the footage was shot in 1080i HDV with a Z1, and the project properties are set fine to that footage.
    I have rendered out the clip (just to check the error trasfurs to DVD – and it does).
    Any help please
    Regards
    Martin
    Martin Phillips replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
