Activity › Forums › Apple Final Cut Pro Legacy › pan centering audio
pan centering audio
Posted by Williebondo on September 13, 2007 at 5:51 pmI’m still struggling with this pan centering business. I know there’s ways around it, but I never had this problem till I upgraded. It’s got to be a setting, but I’ve tried everything. I thought the stereo pair idea would be the fix, but no go. Anybody else with ideas? Driving me nuts!
Ernie Santella replied 19 years ago 3 Members · 4 Replies -
Walter Biscardi
September 13, 2007 at 6:09 pmModify > Audio > Pan Center
What’s the issue?
As I said in your last thread about this exact same issue, Nothing has changed in the Audio Pan controls in this latest upgrade.
By the way, since you started a new thread, it’s quite difficult for anyone who wants to help you to follow along with what’s already been suggested. This is why we discourage folks from starting a new thread about the exact same subject instead of just continuing on the old thread.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Williebondo
September 13, 2007 at 8:48 pmThen it’s has to be a setting somewhere. Any suggestions about what that could be. All I know is, I never had this issue before. I just can’t figure it out and it’s making me nuts. Thanks for the help, though.
Walter Biscardi
September 13, 2007 at 8:50 pmJust make sure you don’t have Stereo Pair applied to the clips you’re trying to center. You can’t center a Stereo pair.
Ernie Santella
September 13, 2007 at 9:06 pmI had this happen to me yesterday. (Not sure if it’s your issue) I copied some footage into a new timeline and the audio was locked left or right. I couldn’t center it either.
What happened was, I had the setting of the sequence wrong. (I can’t remember which setting) but when I reset them correctly for the footage codec, everything panned fine.
So… try creating a new timeline, maybe you have one setting off like I did.
