Activity Forums Adobe After Effects Pan Behind Numerically?
  • Pan Behind Numerically?
    Posted by Aaron Benoit on August 4, 2008 at 7:00 pm
    I was wondering if there was a way to change the anchor point and relative position numerically? I typically use the pan behind tool for this kind of task (to maintain the layout of the comp) but it lacks the precision I’m looking for in my current project.
    I’d do it mathematically if I had to (changing anchor pts and offsetting w/ position), but I figured there had to be a better way.
    Thanks for any ideas/imput,
    Aaron
    Patrick Hearn replied 18 years, 1 month ago 3 Members · 4 Replies
  • Kevin Camp
    August 4, 2008 at 9:17 pm
    you might try using a null object (layer>new>null) as the rotation point for the camera. make the null 3d, then position it where you need to rotate around (you could animate the position if it needed to say track an object).
    then parent the camera to the null. now you can rotate the null to have the camera swing around that point. if you needed to say truck the camera in/out on that point you would just animate the camera (not the null) on its z position.
    is something like this what you were after?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Aaron Benoit
    August 4, 2008 at 9:28 pm
    Hey Kevin,
    Thanks for the advice – but perhaps I didn’t make myself clear – the “pan behind” that I was referring to wasn’t a camera move but instead the actual ‘pan behind tool’ (y). I was trying to figure a way to keep my 2d comp intact while changing anchor points numerically without having to offset the position by hand.
    AB
  • Patrick Hearn
    August 5, 2008 at 8:26 am
    Create an expression on the property: position. (Alt + Click on the stopwatch)
    Enter this:
    x=thisLayer.position[0];
    y=thisLayer.position[1];
    Ax=thisLayer.anchor[0];
    Ay=thisLayer.anchor[1];
    [x+Ax, y+Ay]
    This will at first mess up your comp, you will prob have to rearrange some things, but it will mean you’re able to move anchor point without affecting position.
    (There’s a better way of doing this, I’m sure. So I’m well prepared to be shamed into submission by Dan Ebberts. This was just my first thought, I’ll have another look and post again I I get a better solution)
  • Patrick Hearn
    August 5, 2008 at 8:32 am
    [x+Ax-(width/2), y+Ay-(height/2)]
    That should be better, assuming that previously all your anchor points were in the centre of the layers.
