Activity › Forums › Apple Final Cut Pro Legacy › Pan Audio Center
  • Pan Audio Center
    Posted by Andres Rios on June 9, 2011 at 11:44 pm
    I have a whole sequence with audio which only comes out one channel. Panning the audio to the center solves his issue however, what’s the fastest way to do this? Is there a filter that does this or do i need to go to every individual clip and pan the audio?
    Tim Short replied 14 years, 4 months ago 5 Members · 5 Replies
  • Cody Walters
    June 10, 2011 at 1:45 am
    Andres,
    Fix the pan issue with one of your clips. Then select the clip, copy the clip, then highlight all other audio clips and perform the paste attributes function. Paste the Pan attribute and you should be good to go.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Andres Rios
    June 10, 2011 at 4:18 am
    Thanks.
  • Andrew Rendell
    June 10, 2011 at 5:40 pm
    Or select all your clips on the timeline and press {Control} and {full stop} together.
  • Jeff Greenberg
    June 11, 2011 at 5:29 pm
    Select the track with the T key.
    Modify Menu> Audio> pan Center (CNTRL . )
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Tim Short
    May 15, 2012 at 11:09 am
    Brilliant that !
    Be a bit kinder
