Activity Forums Boris FX Pan and Zoom for 3 points animation.
  • Pan and Zoom for 3 points animation.
    Posted by Nicolas Remond on July 12, 2013 at 1:11 am
    Hello,
    I love Pan and zoom filter, it is extremely intuituive, fast, and produces flawless quality. I am using “AB automation” most of the time, and with the semi automatic and full control modes I have experienced some frustrations. In particular, I cannot manage to make a good smooth and regular animation with 3 stops: travelling from point A to point B, then from point B to point C. Is there a setting than could facilitate such 3 points animation?
    Thanks in advance.
    Nicoremo
    Michael Mccune replied 13 years ago 3 Members · 3 Replies
  • James Macon
    July 12, 2013 at 5:59 pm
    Hi Nicoremo-
    If you change the speed of the animation to accelerate mode or change the interpolation to a curved mode you might get the results your looking for.
    -James
  • Nicolas Remond
    July 13, 2013 at 4:14 am
    Hello James,
    I will try that, thanks!
    Nicoremo
  • Michael Mccune
    August 29, 2013 at 2:19 am
    Nicolas; Can you bring up the graph mode in FX?
    Douglas – Gaijin-Eyes – has a wonderful tutorial on the graph capabilities of FX. It is #16.07.
    There is a huge benefit in *seeing* the FX transformations, as the different interpolation modes yield sometimes surprising or unexpected results.
    It is all mathematical, of course, so the program is not making mistakes, but unexpected jerkiness I have found is easily fixed when one can see the curves and make changes directly in the graph mode.
    Hope this helps.
    Mike
