Activity Forums Avid Media Composer Pan and Zoom flicker problem
  • Pan and Zoom flicker problem
    Posted by James Gordon on February 9, 2008 at 6:59 pm
    Hi all!
    I have figured out how to work the mechanics of the Pan and Zoom feature on AVID. However, when the shot zooms or pans, it’s creating an annoying flicker on the rendered image. Not the entire image, just portions of it. (It generally happens when a horizonal image on the photo crosses a line of resolution or something like that.) I assume this can be corrected somewhere in the settings of the effect, but I have NO idea which one…any ideas?
    Chris Strauss replied 16 years, 7 months ago 3 Members · 2 Replies
  • Jon Zanone
    February 10, 2008 at 2:53 pm
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Chris Strauss
    February 10, 2010 at 5:30 pm
    I am having the same problem as you. I’ve been searching for an solution but have had no success.
