Activity › Forums › Boris FX › Pan and zoom file types?
  • Pan and zoom file types?
    Posted by Jef Huey on October 4, 2009 at 3:04 am
    Just started experimenting with BCC 6 – Pan and Zoom that comes with Avid MC4.
    What are the supported file types? I can not get .tif or .jpegs or many other common file types to load. Am I missing something in the UI?
    thanks,
    Jef
    Matt Mullen replied 16 years, 11 months ago 2 Members · 3 Replies
  • Matt Mullen
    October 5, 2009 at 2:21 pm
    Jef,
    Have you seen the PDF file for this filer. I included it below. It lists the work flow for Automatic, Semi-automatic, and Manual work flows.
    https://www.borisfx.com/Documentation/BCC6AE/BCC%20Pan%20And%20Zoom.pdf
    It seems like you might be missing a step somewhere.
    If you can’t figure it our from the PDF let us know your workflow and what you are trying to do.
  • Jef Huey
    October 18, 2009 at 6:10 pm
    I read the pdf you offered. It does not address my question.
    My question is: what file types does Pan And Zoom support? I can only get PSD files to load. Can other file types such as .tif, .jpeg, or .png be used? If so how?
    Jef
  • Matt Mullen
    October 20, 2009 at 2:51 pm
    Jef,
    I am able to select these files types.
    What OS are you running on?
    Does it throw an error message? Or just not show you the other files?
    Can you post a screen shot of what you see? You may be looking for PSD files only.
