Activity Forums Apple Final Cut Pro Legacy Pan and Scan or Zoom
  • Pan and Scan or Zoom
    Posted by Alan Smith on August 20, 2008 at 2:49 pm
    I am working in an SD sequence but have several HD clips that are being included. Would I get a better quality finished image if I use a BCC Pan and Scan (or similar filter) or the standard zoom to move into the HD footage? Any recommendations for final quality output?
    Kevin Nations replied 17 years, 4 months ago 4 Members · 4 Replies
  • David Bogie
    August 20, 2008 at 2:55 pm
    Some Boris filters employ a separate, sub-pixel rendering engine that is vastly superior to Apple’s. Dunno if this is one of them.
    A dedicated filter designed for smooth and elegant 2D moves is generally easier to keyframe and edit than using the geometry settings for the clip.
    bogiesan
  • Kevin Nations
    May 13, 2009 at 6:26 am
    I am needing to do this also. I have an SD project, ive got mostly SD footage, however I do have some HD clips that I would like to zoom in on and reframe (within the SD frame itself). It was my thinking that I could zoom in on these HD clips up to 100% without loosing quality and making pixels huge and blocky… not so. Why? It is almost like it has actually converted my HD footage to SD before I even drop it onto the timeline.
    Any thoughts?
    Kevin
  • Rafael Amador
    May 13, 2009 at 2:41 pm
    look in the motion tab. Probably they are a 50% or so just to fit in the canvas window.
    Resize them. As you say, until 100% there is not real upscaling.
    rafael
    http://www.nagavideo.com
  • Kevin Nations
    May 14, 2009 at 12:12 am
    yes. as I go into the motion tab with the HD clip selected, the Scale defaults to 37.5%… good. But when i scale the HD clip to 100%, it looks as pixelated as a mosaic artist’s portfolio. It’s like FCP is “interpreting” the HD clip as SD as it hits the timeline.
    Argg! This is frustrating.
    Kevin
