Activity › Forums › Adobe After Effects › Pan and Scan Issues
  • Pan and Scan Issues
    Posted by Aaron Cadieux on August 16, 2006 at 2:37 am
    Hey all,
    I am doing a documentary film with some pan and scans of wood-block carving prints (black and white). I scaned the images at a high resolution (300 DPI). But, because of the nature of the images (a lot of lines and detail), they are very flickery on the motion of the pan and scans. Adding flicker removal only slightly improves the images. Is there anything I can do to reduce and/or eliminate the flickering completely? Any suggestions?
    -Aaron
    Aaron Cadieux replied 20 years, 1 month ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    August 16, 2006 at 2:46 am
    Use Levels to reduce the the blacks and whites by about 10%. Reducing opacity by about 10% will also help. Add some motion blur.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Aaron Cadieux
    August 16, 2006 at 2:53 am
    The problems I am having are similar to the flicker issues when you try and pan on a newspaper image.
    August 16, 2006 at 4:57 pm
    [Cadge31] “The problems I am having are similar to the flicker issues when you try and pan on a newspaper image.”
    Dude, give it a shot. I know what you’re alluding to. The solution(s) I’ve provided has worked for me, many times. If all else fails, then you can always use Premiere’s Flicker Removal which does a much better job than AE’s rendition. And if all of these fail, then add some Channel Blur. It’s all about getting rid of the interlace flickers and, I am assuming that you may also have, chroma crawl artefacts
    Have Fun!
    Roland Kahlenberg
    broadcastGEMs
  • Aaron Cadieux
    August 16, 2006 at 7:58 pm
    Thanks for the advice. I have experimented with different combinations of motion blur and other blurs and have gotten some good results and found something that works. Thanks a lot.
    -Aaron
