Activity Forums Adobe After Effects Pan and Scan in After Effects
  • Pan and Scan in After Effects
    Posted by Cybele Sunday on October 31, 2006 at 2:49 pm
    Hello, I am making a doc short and have a lot of old photos that I will want my editor to pan and scan for me, ala, Ken Burns or Kid Stays in The Picture.
    My question is how should I prep the original photos. Some are 8 x 11 some are small “snapshots”. What settings should I use to scan them for the best possible image?
    I will be creating the moves in After Effects and providing the editor with Quicktime Movs or a MiniDv
    Cybele Sunday
    work is the curse of the drinking class.
    o wilde
    Cybele Sunday replied 19 years, 10 months ago 3 Members · 3 Replies
  • Deadittex
    October 31, 2006 at 11:50 pm
    Video DV …or any SP formate is usually 72 dpi ( so that is a god place to start) however since you are scanning photography you might wanna scan at the 600dpi that mostprinted photography is. . .
    as far as size settings scan however you like for size espeicially if you are moving them aound the larger the better since I assume you are scanning them into photoshop using the import function? Yes?
    Since photo shop is raster based make them bigger then you need on the initial scan you can always do a constrained scale to get them to the size you want in AE …
    tah
  • Broken
    November 1, 2006 at 2:33 am
    It’s pretty easy. It’s all based on the fact that in almost all standard-def NTSC cameras, the horizontal resolution is 720 pixels across.
    For each photo, figure out the smallest 4×3 section you’ll want to see on the TV screen. Then measure it horizontally in inches, divide 720 by that measurement, and you’ll know how many dots per inch you need for your scan of the picture.
    Here’s an example: I have an 8×10 picture. I want to zoom into a head & shoulders shot of a guy in the picture. I measure it, and it will be 2 inches across. Now I do the arithmetic: 720/2 = 360. I’m going to need to scan at 360 dpi. Oh, what the heck, I’ll scan at 400 dpi, a little extra resolution can’t hurt.
    Here’s another example: I have 3×5 snapshot, and I need to zoom into somebody in the background. I measure it… cripes, 3/4 of an inch! Well, let’s do our division: 720/.75 = 960! Yipes! Well, it looks like a scan at 960-980 dpi.
    Here’s a third example: another 8×10 picture. I just need to lose some junk on the edges of the shot, and I’ll be good to go. After measuring, I’m going to need something 7 inches wide. Okay, 720/7 = 102.857142857143… so we’ll call it 120 dpi.
    And that’s all there is to it!
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
  • Cybele Sunday
    November 2, 2006 at 11:29 pm
    Thank you. That does make sense!
    Cybele
    o wilde
