Activity Forums VEGAS Pro Pan and crop issue
  • Pan and crop issue
    Posted by Trudi Mowll on October 18, 2011 at 9:47 pm
    HI,
    When I crop HD video I often get lines through the footage wherever there is movement once I have rendered it. It seems to get worse with each subsequent render. I am using Pro 10e. Is there a way I can fix this? My project is an hour long with crops in a few 10 sec grabs. I am self taught so can I have an easy to understand explanation if possible.
    Thanks heaps!
    John Rofrano replied 14 years, 10 months ago 2 Members · 5 Replies
  • John Rofrano
    October 19, 2011 at 4:10 pm
    [Trudi Mowll] “When I crop HD video I often get lines through the footage wherever there is movement once I have rendered it. “
    It sounds like you have an interlacing problem. Is your source interlaced? (it sounds like it is). Is your project set up for interlaced footage? More importantly, what do you have your Deinterlace Method set to in your project properties? It sounds like you may have incorrectly set it to “None”.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Trudi Mowll
    October 19, 2011 at 8:15 pm
    thanks, i set it to blend and this seems to have solved the problem.
  • John Rofrano
    October 19, 2011 at 8:30 pm
    [Trudi Mowll] “thanks, i set it to blend and this seems to have solved the problem.”
    Yea, if you are working with interlaced video, you should never, ever select “None” as the deinterlace method.
    ~jr
  • Trudi Mowll
    October 19, 2011 at 8:50 pm
    I have no idea what interlaced and deinterlaced means – i guess I should do some google searching and background reading 🙂
    But at least it is set right now.
    I am so glad I have found this forum – I’m going to learn a lot and get my many questions answered!
    thanks
  • John Rofrano
    October 20, 2011 at 2:27 am
    [Trudi Mowll] “I have no idea what interlaced and deinterlaced means – i guess I should do some google searching and background reading :)”
    Wikipedia is a good source for stuff like this. In short, interlacing was used in early Television broadcasts to overcome limitations in technology and it never went away even though there is no need for it anymore. What happens is a single frame gets split into odd and even fields for transmission. The act of deinterlacing brings these separate fields back together to create a complete frame. Vegas needs to know if a frame is composed of fields so that it can correctly process it. When you set the deinterlace method to “none” you turned this processing off which is why your interlaced footage didn’t look correct when cropped.
    [Trudi Mowll] “I am so glad I have found this forum – I’m going to learn a lot and get my many questions answered!”
    Welcome to the community. 🙂
    ~jr
