Activity › Forums › VEGAS Pro › Pan and Crop drops from site.
  • Pan and Crop drops from site.
    Posted by Dan Achatz on September 30, 2005 at 12:27 am
    When I start the pan and crop feature, my pan and crop menu opens up and drops off the screen. Something like this happend before and I remember that there was a special start sequence that resets everything.
    Does anyone remember the sequence?
    Dan
    Edward Troxel replied 21 years ago 2 Members · 2 Replies
  • Dan Achatz
    September 30, 2005 at 12:53 am
    If it’s above the top, it will still be above the top no matter what resolution the screen is set for. Increasing the resolution will only helps if the window is lost off the right side or the bottom side.
    Try this: assuming the Pan/Crop window is the currently active window (it should be if you’ve just clicked the Pan/Crop icon in an event), press Alt-spacebar to open up the control menu for the window. Type M to select the Move command. Use the arrow keys to move the window back onto the desktop. Press Esc to exit the Move command
  • Edward Troxel
    September 30, 2005 at 1:36 am
    I usually recommend just change the screen resolution to a higher resolution, locating the window, and dragging back to the main area.
    WORST CASE SCENARIO: hold down CTRL-SHIFT when starting Vegas. This will reset everything back to factory defaults (including the settings you WANTED changed).
    Edward Troxel
    JETDV Scripts
