Activity Forums Adobe Premiere Pro PAL/NTSC Problem
  • PAL/NTSC Problem
    Posted by Susan Miller on October 29, 2009 at 7:16 am
    Hi everybody,
    i`m just working on a DVD Project.
    Yesterday I was told that the project won`t be in PAL as indicated first, they want do it in NTSC.
    May question now is. I`m I able to get may PAL 48 KHZ project into a NTSC 48 khz project.
    It took month to finish the first ten minutes therefore I won`t start all over again.
    The raw material I got from the project were *.vob files which I transformed into *.mpg files.
    Thanks for all help
    Dan Plonsker replied 16 years, 10 months ago 4 Members · 3 Replies
  • Jon Barrie
    October 29, 2009 at 8:45 am
    If your media is not NTSC you’re facing some issues here. you’ll have to do some converting which is not the best done with software. You van import you’re old project to a new NTSC project in cs3
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Darren Edwards
    October 29, 2009 at 2:56 pm
    Jon’s right, software is terribly slow doing pull up/pull down of
    frame rates/formats, but it can do it, at least. There’s even a
    couple of hintful Cow tutorials scattered around here on pull up/down
    in software like AE.
    Darren.
    youtube.com/darrenpce
  • Dan Plonsker
    November 2, 2009 at 2:05 pm
    If your raw files are PAL, I would finish your project in PAL and than make a movie out of it and convert to NTSC with another hardware or software (procoder etc.)
