Activity › Forums › Letters to the COW Team › pal/ntsc issues…please help!
  • pal/ntsc issues…please help!
    Posted by Priya Patnaik on December 6, 2009 at 5:02 pm
    Hi everyone,
    I’m using the Avid Media Composer to edit a project. Half of the footage I have is on NTSC and the other is PAL ( Everything is DV) I know Avid does not mix PAL and NTSC footage on the same timeline. Question one – Does FInal Cut Pro? If it does, I might consider switching editing softwares
    Secondly, if none of them allow me to use PAL and NTSC on the same timeline/project, I would need to convert the footage. Do you have suggestions about how I can convert the footage with the least possible quality loss.
    Any suggestions would be much appreciated!
    Priya
    Chad Brewer replied 16 years, 9 months ago 2 Members · 1 Reply
  • Chad Brewer
    December 10, 2009 at 2:16 am
    Call TeleVersions.
    Digital, motion compensated standards conversions (NTSC<->PAL) since 1996.
    https://www.televersions.com
    312-642-9488
    Or, you can render your life away in Final Cut Pro with poor results.
    Chad Brewer
