Activity Forums Adobe After Effects PAL/NTSC conversion
  • PAL/NTSC conversion
    Posted by Gregoire on April 5, 2006 at 1:17 am
    I’ve been trying to convert non-interlaced PAL footage (quicktime) to non-interlaced NTSC footage. Is there anyway within AE to do this without the motion staggering? I’ve been taking the PAL footage into a new comp, changing the comp frame rate to 29.97 and then rendering it out at 720×480. Is this right?
    Roland R. kahlenberg replied 20 years, 5 months ago 3 Members · 2 Replies
  • John Dickinson
    April 5, 2006 at 2:17 am
    Hi Gregoire,
    This is a frequent question. Do a search in the archives and you’ll find plenty of information 🙂
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Roland R. kahlenberg
    April 5, 2006 at 3:27 am
    John’s right, do a search and you will find lots of answers. My only other input is to take into consideration the different pixel aspect ratios that PAL and NTSC. So, the job will require frame-rate conversion and also pixel sapect ratio conversion.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
