Activity Forums Avid Media Composer PAL workflow for 24P
  • PAL workflow for 24P
    Posted by Rod Main on July 8, 2008 at 6:46 pm
    Any suggestions for the best workflow for editing a PAL project which has been originated on tape at 24P? Do I do it in a 25P project with time-code conversion? It is destined for a conform and online on DS Nitris. Offlining on Avid Media Composer.
    Thanks in advance
    Job Ter burg replied 18 years, 1 month ago 2 Members · 2 Replies
  • Job Ter burg
    July 11, 2008 at 6:35 am
    Common workflow for tape based 24p posting in the PAL world is to set the deck to 25fps playback and also (separate setting!) to 24->25TC conversion. Then capture into a PAL 24p project. Picture will be slowed down, and any 24 or 25TC based EDL can be generated, since you can copy-convert the Start TC (25TC) into the TC24 column and it will calculate back to the original 24TC. My very first HDCAM 24p project was done this way, and finished in Avid DS. I don’t think there were any issues, except for some motion effects that did not translate well back in those days (but this was 2003 or 2004 or so).
    You have to wonder about sound, though. It’s usually a better idea to work double system, but if you do need to use the sound from the tapes, you need to figure out a way to do that, without compromising the sound quality.
  • Job Ter burg
    July 11, 2008 at 6:37 am
    There’s of course also another option, which is to capture in 1080/24p DNxHD36, then offline in HD, or transcode to 24p PAL. This would allow you to capture picture and sound in one go, without any speed conversions during capture. But you would need an Avid with HD capturing possibilities.
