PAL Widescreen question – After Effects
Hi there
I’ve just switched over from using Flash for some DVD projects I’ve been working on (reached the limits that Flash can go for his project). My background is in design and flash development not video editing, hence the probably really basic question.
The movie is to be output to DVD for use on widescreen PAL. In after effects I’ve used the ‘Pal D1/DV widescreen 720×576’ comp. On my monitor this looks condensed and I know this is because my screen uses square pixels, but even if I export my movie to a quicktime file, the movie still looks standard rather than widescreen, is this correct? Reason for asking is that I’ve extracted some clips from DVD footage and that looks widescreen when I play it back in quicktime. I’ll be supplying the exported .mov file to a third party who will be producing the DVDs.
Finally, the client who will be approving the project will make a comment that the movie looks condensed when checking on my monitor, is there a way around this?
Thanks in advance
