Activity › Forums › Panasonic Cameras › PAL vs NTSC
PAL vs NTSC
Posted by Andrei Bocharnikov on June 20, 2006 at 4:58 pmWe are in Europe. We’r going to buy Panasonic HVX200 to shoot HD. Here in Europe it is really difficult to get price under 6000 euro (about $7600) No PAL version on USA stock. Cheapest NTSC camera is about $4000. Huge price difference.
Do we really depend on PAL if we shoot HD, 24 and we going to produce it for NTSC and PAL market. Again we do not going to use DV format at all. Is it ok if we here in Europe will use NTSC camera.
Thank you, Andrew
Andrei Bocharnikov replied 20 years, 3 months ago 5 Members · 13 Replies -
Noah Kadner
June 20, 2006 at 5:13 pmOne issue you may run into is flickering of certain lights because they are on 50 cycles rather than the 60 in North America. And you’ll be looking at more downconversions but in general it’s not a deal breaker for most productions.
Noah
Andrei Bocharnikov
June 20, 2006 at 5:49 pmthank you, Noah.
further questions:
— is it problem to convert NTSC HD footage to PAL HD and is it necessary at all?
— what is the best or most used format to put HD to DVD? is it BlueRay or HDDVD. Is it problem to play NTSC HD on PAL HDDVD set-top player. Is there any HD set-top on the market?
Andrew
Noah Kadner
June 20, 2006 at 5:55 pmWell first of all there is no such thing as PAL and NTSC in the HD world- it’s more a question of frame rate and downconversion to standard definition. BluRay vs. HDDVD is a- a subjective question b- a moot point as there are not burners or players widely available for both yet.
Noah
Andrei Bocharnikov
June 20, 2006 at 6:02 pmok, thank you again.
— What problem i could meet because of frame rate difference?
— what is better to downconvert to SD format. we need it both NTSC and PAL DVDs at the end.
Andrew
Noah Kadner
June 20, 2006 at 6:10 pm25p vs. 24p 60i vs. 50i. etc. Way more tech details here:
https://www.adamwilt.com/DV-FAQ-tech.html
The PAL or NTSC models of the HVX would make arguably equivalent NTSC and PAL downcoverts. But again you’d be dealing with a frame rate convert for one or the other. I’d recommend the Nattress plugins to handle this:
https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
Noah
Andrei Bocharnikov
June 20, 2006 at 7:10 pmand what is better looking convert: from PAL HD to NTSC SD or NTSC HD to PAL SD? i mean where i will struggle more with frame rates.
thank you, Noah
Andrew -
Noah Kadner
June 20, 2006 at 7:27 pmLike I said- in my opinion they are about equal because the HD source is very high quality.
Noah
Jan Crittenden livingston
June 20, 2006 at 7:59 pmHi,
Your assumption that the NTSC camera is around $4000, is flawed. Those companies that offer it for that are only advertising it for that price to get you to call them, then once they have you, they will sell you the battery,the power supply and all of the things that normally come with it at a premium. Then they will tack on a bunch of useless accessories, like wide angle converters that vignette and such. No the legitimate units here are going for about $5500-5600. Much under that and there is something wrong. Under $5000, walk away as fast as you can because you are getting scammed, you won’t know it until you have the camera and your credit card bill a month later.
Hope this helps,
Jan
Jan Crittenden Livingston
Product Manager, DVCPRO, DVCPRO50, AG-DVX100
Panasonic Broadcast & TV Systems -
Andrei Bocharnikov
June 20, 2006 at 9:00 pmwow… it is good to know.
we have one offer for $5100 without P2 cards. you think it is scam?
Andrew
June 20, 2006 at 9:02 pmOff hand, I would say yes this is a scam.
