Activity › Forums › Adobe After Effects › PAL to NTSC
PAL to NTSC
Posted by Vegard Sorby on December 12, 2005 at 1:07 pmDoes anyone know of a good method of making PAL files into NTSC? (I’m sending a showreel from Australia to USA).
Cheers!
VegardAccountneedsrealnameupdate replied 20 years, 9 months ago 3 Members · 2 Replies -
Filip Vandueren
December 12, 2005 at 1:21 pmThere are a number of plugins out there that do frame-blending for changing framerate.
And even some that are spec. designed for transcoding.But if your material is not interlaced, you can try this:
– create an NTSC comp, but change the frame-rate to 24 fps
– re-interpret your PAL-footage and conform to 24fps (it will slow down about 4%)
– drop the footage into the comp and make it fit by scaling down a bit.
– now render, and in Render settings, after choosing a field-render type, choose any PULL-down.You’ll get a 24P effect
This is the best way to convert to NTSC if and only if you can live without fields, and the 4% slowdown doesn’t bother you.
I know, those are two big “ifs”, but best of all it doesn’t use any plugins. -
December 13, 2005 at 1:04 amAs above but in my experience you’ll probably get a decent result by just bringing the footage in, putting it in an ntsc comp and doing a field render without conforming to 24 first, after effects will add pulldown, it won’t be a nice 3:2 pulldown like the previous method but it will look ok and you don’t need to worry about audio. Make sure you interpret your source correctly if it has fields already (upper or lower field first). As the previous post stated it’s easier if you can deliver it with fields, if you need progressive some kind of plugin will be necessary (you can always get some result by playing with frame blending or a staight progressive render but it won’t look very nice, after effects will just duplicate frames and motion will look stuttery)
Glenn Stewart
1k studios
