Activity › Forums › Apple Final Cut Pro Legacy › PAL to NTSC conversion
Posted by Sb6755 on November 6, 2006 at 11:14 pmI am working on a Doc which was shot mostly 24PA. I must cut in a 23.98 timeline to get back to film (DI) at finish. A few of my DV tapes were shot PAL which I have captured. I’m on FCP 5. Is is possible for me to convert those PAL clips to NTSC in FCP 5? If so, can someone help me with a workflow?
I also discovered some material shot 30 frame with 32 kHz sound. Is it appropriate for me to apply reverse telecine to those clips to enable cutting in the same 23.98 timeline? Is that the correct approach for me knowing that I must finish on a DI?
Ron James replied 19 years, 10 months ago 6 Members · 13 Replies -
Steve Eisen
November 6, 2006 at 11:22 pmCompressor can do it for free.
Nattress plug-in is $99 well spent.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Gary Adcock
November 6, 2006 at 11:37 pm[Steve Eisen] “Compressor can do it for free.”
Steve
yes it can almost give you PAL, but you get exactly what you payed for.stick with Nattress.
gary
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Sb6755
November 6, 2006 at 11:37 pmSteve,
Thanks. Please excuse my inexperience with FCP as I’m using it for the first time. I’m an old school AVID editor. Do you have the time to walk me through what I’d have to do to make the conversion using compressor? Or can you refer me to an article with instructions?
Sb6755
November 6, 2006 at 11:42 pmGary,
Thank you. Where is the best place to get Nattress?
Also are you able to address the second part of my original post. Am I correct in using reverse telecine on the 30 frame material?
Sb6755
November 6, 2006 at 11:45 pmSteve,
I’ll go for the plug in. Thanks. Where is the best place to get it?
Also, are you able to address the second half of my original post? Am I doing the correct thing by using the reverse telecine tool after capture of 30 frame material?
Gary Adcock
November 6, 2006 at 11:51 pm[SB6755] “Is it appropriate for me to apply reverse telecine to those clips to enable cutting in the same 23.98 timeline?”
No it will not look correct.
Graeme Nattress makes a standards conversion ( 24 to 25) product also. (nattress.com)
gary adcock
Studio37
Sb6755
November 6, 2006 at 11:59 pmGary,
So how should I handle the capture of my 30frame NTSC footage for cutting in a 23.98 timeline? Should I capture at 29.97 and then use the Nattress to convert it? I though reverse telecine was designed to change NTSC 30 frame to 24 frame.
Walter Biscardi
November 7, 2006 at 12:34 am[SB6755] ”
Thank you. Where is the best place to get Nattress?”Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Steve Eisen
November 7, 2006 at 12:54 amYou always get what you pay, or don’t pay for.
Steve Eisen
Director-At-Large
The Edit doctor
November 7, 2006 at 8:56 pmDO NOT reverse telecine footage shot at 30fps (29.97) to 24fps (23.98). Reverse Telecine is for 24fps material that has had the 3:2 pulldown added to it laying it on a 29.97 tape –
Truly… just get the Nattress Standards Converter from http://www.Nattress.com. Follow the directions you will be taking a 29.97fps clip and converting it to 23.98 clip using interpolation that smoothes out the fields and frames and keeps the runTIME the same. Do this to all those 29.97 clips first then use them in your 23.98 afterwards.
Mike (::[ ]::)
