Activity Forums AJA Video Systems Pal to NTSC
  • Pal to NTSC
    Posted by Leonardo De mai on April 8, 2011 at 11:41 pm
    Hello everybody,
    do you know if it is possible to convert directly from a SD signal (SDI) 720X576 PAL to NTSC ?
    I just have production in Korea and I record in PAL system, but I have to produce in the same time a signal for local broadcaster.
    Thank you for you help
    Leonardo De Mai
    Leonardo De mai replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    April 11, 2011 at 2:35 pm
    The KiPro does not so standards conversion unfortunately. For that, you will need a dedicated converter.
    Jeremy
  • Leonardo De mai
    April 11, 2011 at 8:02 pm
    OK thank you in fact I have try several option without result .
    Thank
    Leonardo
