Activity Forums AJA Video Systems PAL to NTSC
  • PAL to NTSC
    Posted by Michael Bugera on September 12, 2005 at 9:41 pm
    Captured and edited PAL footage into FCP with IO LA into a PAL FCP sequence. Is it possible to successfully send out signal to an NTSC machine for record? Preliminary tests are not suxxessful.
    Bugsy
    Tony! Hulette replied 21 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    September 13, 2005 at 4:09 pm
    I do not think the io is a standards converter, but you can use a filter from Graeme Nattress that will convert your PAL timeline to NTSC. I’ve done this before (except from NTSC to PAL) and it works great. http://www.nattress.com Click on the standards conversion tab. The render times might take a while depending on length of your program and your machine, but it’s well worth it to have the control.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Tony! Hulette
    September 15, 2005 at 6:32 am
    I’d suggest putting it on a PAL tape and sending it out for the NTSC conversion. Its easier, faster, better and probably cheaper in most cases.
    Tony!
