Activity Forums DVD Authoring PAL to NTSC
  • PAL to NTSC
    Posted by Krish Shrikumar on December 9, 2010 at 1:14 am
    Hey,
    I was looking for some advice,
    I’m based in the UK and have a project that is currently in PAL, but I need to send it over to the states and I need to convert to NTSC. From reading articles online, there doesn’t seem to be definitive guide on conversion. I’ve gone through compressor and exported an NTSC version but I wanted some advice to ensure that it works (I dont have an NTSC dvd player to test it on)
    Thanks in advance,
    Krish.
    p.s im on Adobe Encore & DVD Studio Pro.
    Michael Sacci replied 15 years, 9 months ago 3 Members · 4 Replies
  • Daniel Ludwig
    December 9, 2010 at 9:18 am
    Hi Krish,
    you can playback NTSC-DVDs on PAL-player but it wont work the other way round.
    if you need to convert PAL to NTSC I would advice to use compressor with framecontrol. you should go 29.98 NDF and encode it as 29.98 NDF (progressive) otherwise you could get in trouble with the field-dominanz.
    note: it´ll take a bit of time to create your NTSC-film out of your PAL-material.
    cheers
    danny
  • Krish Shrikumar
    December 9, 2010 at 10:45 am
    Thanks Daniel.
    I’ve done that and it seemed to have exported okay. Are there anything I need to lookout for when burning the DVD on Encore?
    Cheers,
    Krish
  • Daniel Ludwig
    December 9, 2010 at 5:32 pm
    hi again,
    I wold prefer DVD SP but Encore will be OK as well.
    cheers
    danny
  • Michael Sacci
    December 9, 2010 at 5:39 pm
    Is your footage 25i or 25p? If you shot and edited your footage at 25p you should retime the video to 24p NTSC, there is zero quality loss that way.
