Activity Forums Broadcasting Pal System
  • Pal System
    Posted by Woodie on July 16, 2005 at 1:15 pm
    Goodday.
    I wonder if you would be able to help me. In South Africa we use PAL. Thus, I need to setup my external TV with PAL color bars. I’ve search high and low thru the net and I can only find ways to setup NTSC monitor with SMTPE color bars.
    Do you perhapse know how to correctly use PAL color bars on a consumer TV so I can at least gain some support from my little tv.
    Thanks for a great site.
    Rudi
    Rj Hewitt replied 21 years, 2 months ago 2 Members · 1 Reply
  • Rj Hewitt
    July 17, 2005 at 10:39 pm
    Pal colour bars do little to help setup a TV compared to the NTSC version, which includes contrast and brightness test patterns. The best test pattern is pluge. This gives a peak white and black to help correctly set the contrast. Brightness levels are set by additional vertical bars. These are adjusted so they are just visible above the black background.
    Try doing a Google for pluge and you should get your answer.
