Activity Forums Blackmagic Design PAL SD monitoring during DVCPRO HD 1080i50 editing
  • PAL SD monitoring during DVCPRO HD 1080i50 editing
    Posted by Neil Ryan on March 20, 2007 at 4:13 am
    I have imported some Panasonic P2 footage, made a Sequence using an Easy Setup for DVCPRO HD 1080i50 but changed the Video Playback to Pal 10bit (720×576), cut some footage into the seq;
    the sequence plays realtime without rendering;
    but I can’t see it in realtime on the PAL SD monitor.
    The Decklink prefernce pane shows ‘Enable HDTV Up/Down Converter’ is set to
    Output: HD to SD Letterbox 16:9 and
    Input: Off
    In FCP, External Video is set to all frames.
    Sould I be able to view my HD seq on the PAL SD monitor, and if so, what am I doing wrong?
    Thanks.
    Neil Ryan replied 19 years, 5 months ago 1 Member · 1 Reply
  • Neil Ryan
    March 22, 2007 at 2:55 am
    Some folks on the FCP forum pointed me in the right direction, I got it to work by setting the Video Playback to Blackmagic HDTV 1080i 25Hz – 8 Bit (1920 x 1080) setting;
    however, originally, I had been trying the Blackmagic HDTV 1080i 25Hz – 10 Bit (1920 x 1080) setting, but this played back in realtime WITHOUT any down conversion, so I got 1024×576 pixels out of the 1920×1080.
    That shouldn’t happen, should it?
