Activity Forums Adobe After Effects PAL rendering, output no audio
  • PAL rendering, output no audio
    Posted by Albert Lumanas on May 30, 2008 at 4:09 pm
    Dear Sir/s:
    I hope that you could help me find a solution about this clip. I have this video that was extracted in a Sony camcorder HD. I tried to import in encore as a timeline to build into a dvd but i got “stream requested does not exist” but the clip is working fine.
    Again, I imported the clip to AE7, and tried to render but there’s no audio that was rendered. In my composition, i used PAL D1/DV Widescreen, in my pixel aspect ratio, i used D1/DV PAL Widescreen (1.42). In my render output, i used MPEG2 using PAL option.
    Hope you could help me and more power to all.
    Regards,
    Albert
    Albert Lumanas replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
