Activity Forums VEGAS Pro PAL Render – interlaced?
  • PAL Render – interlaced?
    Posted by Joazon on August 1, 2007 at 6:56 am
    I Have a huge problem!!
    I was shooting in Sony DSR-250P and used widescreen imaging by selecting the 16:9 mode in the menu.
    I have editing the movie with AVID software and make it quiktime reference to rendering in VEGAS 7.0. software.
    When I was rendering the movie, and burned this in DVD format, the picture on tv is terrible. Including the fast moves. I know that the problems are interlaced systems. But what can I do that problem, because I want to pictures seems good on TV monitor. This is some facts on my render properties on VEGAS software. Is that somenthing wrong or could I have been change something properties and how??
    My render facts:
    Project Properties:
    PAL DV WideScreen (720×576; 25 fps)
    Field order: Lower field First
    Pixel Aspect Ratio: 1,4568 (PAL DV WideScreen)
    Deinterlace method: Blend Fields
    Clip Properties:
    Render Properties:
    MPEG-2
    Output Type: DVD (720×576)
    Aspect Ratio: 16:9 Display
    Profile: High Profile; Level: High Level
    Field order: Interlaced, Bottom Field First
    Video Quality: High (32)
    Constant Bit Rate (bps): 6 000 000
    Sampling format: 4:2:0
    Gary Kleiner replied 19 years, 1 month ago 2 Members · 2 Replies
  • Gary Kleiner
    August 1, 2007 at 5:33 pm
    AFAIK, your camera may have a widecreen or letterbox mode, but it is a 4:3 camera, and it is just masking to make the letterbox, so you really just have 4:3 video there, so have your project and render settings be 4:3. Yes, it should be interlaced.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Gary Kleiner
    August 1, 2007 at 6:40 pm
    Also, you can try bumping up your bit rate some more.
    Gary Kleiner
