Activity Forums VEGAS Pro PAL project to NTSC dvd??? Advice needed ASAP
  • PAL project to NTSC dvd??? Advice needed ASAP
    Posted by Luke De botte on June 11, 2012 at 9:01 pm
    I have made a pal project in sony vegas platinum 10 from which I need to make both Pal and NTSC dvd’s (for shipping to America) I would like to know that if a project created in Pal can then be rendered as NTSC using vegas or is there another solution to create NTSC dvd’s from this project??
    Nigel O’neill replied 14 years, 3 months ago 3 Members · 2 Replies
  • Dave Haynie
    June 12, 2012 at 12:19 pm
    I have gone from NTSC to PAL in the past… it can be done.
    There are two ways to deal with the frame rate differences: interpolated rendering or “cheat”. I did an interpolated rendering going from NTSC to PAL, 29.97fps -> 25fps, in Vegas. After some experimentation, I used some high quality settings, let Vegas do the rendering, and it took just over 8 days. But that was a few computers ago.
    The “cheat” is for going from PAL to NTSC. Simply put, you lie about your video and claim that it’s 24fps, not 25fps, then do a 3:2 pulldown render — or in Vegas terms, render to “NTSCFilm” (23.98fps) rather than plain NTSC. This will slow your sound down by 4%, so if there’s music or anything really sensitive on it, you can do a pitch-neutral length conversion in something like SoundForge.
    I imagine, if you simply change your PAL DVD project to NTSC and tell it to render, Vegas will render it, and you’ll get SOMETHING. The big problem is that if the render isn’t smart enough, you’ll see weird interlacing effects and other problems. But that’s the easy one to try, assuming you have a way of viewing NTSC DVDs (I know pretty much every DVD player in the UK will play NTSC, sometimes output as “PAL-60”, not sure about elsewhere out your way).
    -Dave
  • Nigel O’neill
    June 13, 2012 at 12:03 pm
    It can be done, and I have done it (PAL, PAL > NTSC) following advice on this forum, but darned if I can find who posted it 🙂
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
