Activity Forums Compression Techniques PAL MXF File Creation Workflow
  • PAL MXF File Creation Workflow
    Posted by Michael Pfost on February 2, 2011 at 6:01 am
    Hi all —
    I need to confirm my workflow of a NTSC video converted into a PAL MXF File (IMX-50 D-10, Op1a, BES Audio) for broadcast in Australia.
    1. I captured the video into a ProRes 4:2:2 NTSC file (720×486).
    2. I converted the video (in Compressor) to PAL ProRes 4:2:2, 720×576, Upper Field Dominance, 25fps.
    3. I then used Episode Pro to convert the PAL ProRes 4:2:2 file into a MXF file (IMX-50 D-10, Op1a, BES Audio).
    Does this sound right? I originally used this work flow, but kept the lower field dominance and it was rejected by the network in Australia due to field reversal. I did not realize that they required Upper Field Dominance.
    I appreciate any input.
    Michael Pfost replied 15 years, 7 months ago 2 Members · 3 Replies
  • Michael Pfost
    February 14, 2011 at 8:53 pm
    Well — I didn’t receive a response – LOL — but this workflow is correct. Episode Pro creates perfect MXF files on a Mac.
  • Craig Seeman
    February 14, 2011 at 9:48 pm
    I’m a heavy Episode user but hadn’t tried your specific workflow.
    There is a COW Episode forum so posting there might have received a response from someone who had done this.
    https://forums.creativecow.net/telestream_episode
    Of course some COW hand would bite your head off for double posting but not I.
    BTW thanks for posting back because even a self confirmation will be helpful to others who are working through this workflow.
  • Michael Pfost
    February 14, 2011 at 9:58 pm
    Ahh – I didn’t see the specific forum for Episode Pro. Good to know 🙂
    Thanks for your response as well…
